smokes at idle and taking off good compression no overheat problems.Is this bad valve guides or seals.does not smoke after cleared out
Aug 17, 2010 at 3:04 PM
✓Experienced Mechanic
Does this happen when you first start the car only?
Aug 17, 2010 at 5:24 PM
Usually, valve seals allow oil to drain into the cylender when the engine is off. I wonder if the drain plugs are clogged in the head and causing the head to hold too much oil. Have you ever taken the valve covers off?
Aug 18, 2010 at 5:15 PM
Usually valve guide seals will only cause the smoke when the engine is first started, or it can happen under full accelleration. Since yours only happens when the engine is warm, I have a feeling the ports in the cylender head are partially plugged and cauising oil to drain back the oil pan slowly. As a result, there is a build up of oil in the head causing the smoke.
