1988 Dodge Caravan
KEVINB1964
  • 1988 DODGE CARAVAN
Engine Performance problem
1988 Dodge Caravan 6 cyl Two Wheel Drive Automatic
1988 dodge caravan loses power climbing hills how can I fix this problem?
Thursday, May 20th, 2010 AT 5:16 PM
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Thursday, May 20th, 2010 AT 8:42 PM
