1987 Dodge Caravan has trouble starting
DANSU
When I go to start it sometimes it just clicks when I turn the key, no other noise. I have to keep turning it over and over until it finally starts. Sometimes it sounds like it might start but fails but mostly it's just a single click noise. Sometimes it starts fine but I'm worried about it not starting sometime when I have to pick up my kids. Any help is so so appreciated.
Oct 19, 2006 at 2:53 PM
RAGS729
  • 29 POSTS
A good place to start is with battery cables, check to insure they are tightly connected by trying to wiggle them on the terminal if they move they need to be tightened, also make sure they are not corroded.
Oct 20, 2006 at 1:58 AM
DANSU
Something I forgot to mention, the interior lights are on bright as ever and the headlights work no problem which led me to believe it wasn't a problem with the battery. Plus the battery is a new one only 1 month old.
Oct 20, 2006 at 2:53 AM
RAGS729
  • 29 POSTS
Even though the battery is new and the lights are bright you could still have a loose or bad cable, a starter draws considerably more power then your lights and other accessories, if not a cable then it sounds like it could be a bad starter.
Oct 20, 2006 at 4:54 PM
NINA ENTRERI
  • 6 POSTS
It's the starter. Replace it soon, as if it has an excessive draw, it may damage your battery.
Nov 3, 2006 at 8:55 AM
