1985 Dodge Caravan
20,000 MILES • 4 CYL • FWD • AUTOMATIC
SASSALITAFL
My car will not start ...the battery is fine replaced a bad start was running although slow to crank over due to being cold....any suggestions???
Dec 11, 2009 at 8:37 AM
CH112063
  • 1,320 POSTS
Is your battery not starting the car ayt all. Do you have any electrical power at all? Is this a new battery? When you turn the key, do you hear anything and will it takec a jump start? If you look under 'site map' it explains how to test a van like yours for a no start, no crank.
If you would like any personal help, I can tell you anything you may need. OK?
Dec 11, 2009 at 11:55 AM
