on at start up for a few seconds telling me to change oil?
45,000 MILES • 4 CYL • FWD • AUTOMATIC
STEVE HONEYMAN
Hi, wonder if anyone can help..
I'm a brit on a climbing roadtrip around the US, I've got a rental Dodge Caliber for the next month and have just driven up Sand Diego to Bishop (CA) 350 miles or so with no probs..
Just yesterday however a 'warning' message comes on at start up for a few seconds telling me to 'change oil', however it then goes off after a few seconds - I'm assuming that this is kinda precautionary at the moment as no warning lights come on at any other point..?
Problem is I have to drive over to Salt Lake City tomorrow (525 miles or so..) I'm no mechanic, and definitely can't afford to get the work done so wondered if it would be safe to drive over to SLC and then give it to the rental company there.. there's no manual with the car so I can't check this message out either..
Any help / advice would be greatly appreciated..
Steve.
Oct 30, 2009 at 11:43 AM
  • 110,248 POSTS
The oil change indicator is based on the mileage since it was last reset. The oil may have just been done, but if it isn't reset, it will tell you to change it. Here is what I suggest: Confirm the oil is full and clean so no damage happens to the engine. If it is, reset the light.
To reset the light, turn the key to the run position (engine off) and press the throttle pedal to the floor three times within five seconds. Turn the key off and it should be reset.
Aug 25, 2021 at 2:31 PM
