How to replace radio. Iwant to replace factory single disk unit with 6 disk factory unit.
Apr 1, 2009 at 12:51 PM
✓Experienced Mechanic
Basically, remove the trim from around the stereo and there will be two bolts holding the radio in. Remove them and slide out the present radio. There will be two plug in the back, a ground strap, and antenna wire that need removed. Once removed, the radio will come out and just replace it with the new one.
Nov 2, 2009 at 2:12 AM
