2007 Dodge Caliber Stuck
42,000 MILES • 4 CYL • 2WD • AUTOMATIC
VIKTORVOND
"Engine light comes on, car can't go faster than 25 miles an hour, 5 miles an hour uphill, pedal to the floor and no rpm gauge response. oil is fine fluids are fine, don't know where to check the tranny fluid though
Nov 4, 2009 at 6:00 AM
MATHIASO
  • 1,209 POSTS
have it diagnose and get back with the code(s)
and we'll help
it seems like it is TPS problem.
Nov 4, 2009 at 9:16 AM
VIKTORVOND
[quote:d0a316046f="mathiaso"]have it diagnose and get back with the code(s)
and we'll help
it seems like it is TPS problem.[/quote:d0a316046f]
What is a TPS problem?
Nov 4, 2009 at 1:11 PM
MATHIASO
  • 1,209 POSTS
the throttle position sensor(TPS) is usually located on the side of the thottle body.
TP sensor faillure is common because it has parts that moves each time the accelerator is depressed or released.
it may be or not be the actual problem.
if you can get the code(s) anytime, I'll help.
autozone has campagn to do it for free.
Nov 5, 2009 at 6:33 AM
