2007 Dodge Caliber starter
70,000 MILES • 4 CYL • FWD • MANUAL
CHUCK518
i have put 2 starters on this car in the pat month both have burned up what can cause this the factory one burned up first then went to the dealer ship and bought 2 more
Dec 12, 2009 at 1:23 PM
CH112063
  • 1,320 POSTS
If I had this problem I would call the nearest dealer, there are weak battery and starting issues all revolving around a couple of service bulletins, I don't want you to waste your time but call and mention the service bulletin. You'll need your vehicle identification number.
It is only for specific build dates. ok
08-052-06
And I hope this information helps, as only a car with extremely long cranking times or a very tight engine to turn over can usually cause this.
Jan 22, 2010 at 8:06 AM
