2007 Dodge Caliber different wheel sizes
MARK MCDADE
Tires and Wheels problem
2007 Dodge Caliber 4 cyl Two Wheel Drive Automatic
can i change the wheel size with out causing troubles ? have the 17" on now but would like to change to 15 or 16 as I have those tirwe on hand. I heard that the wheel size regulate the trans. operations
Dec 26, 2009 at 4:42 AM
CH112063
  • 1,320 POSTS
Each car has tire and wheel information, and gross vehicle weight specs. It is on a decal, a plate located on the drivers door, or its opening. A different wheel needs to be set into the transaxle computer's memory. Using a scan tool. Sorry. I don't want you to get in trouble with gear ratios and odometer problems.
Dec 29, 2009 at 10:34 AM
