alternator
48,900 MILES • 4 CYL • 4WD • AUTOMATIC
SHELLBASS1
how to replace an alternator
Feb 8, 2010 at 2:22 PM
  • 110,248 POSTS
Disconnect the battery, remove the serpentine belt, unplug the wiring behind the alternator, then just unbolt the alternator from the brackets. This guide will walk you through the steps with instructions in the diagrams below to show you how on your car.
https://www.2carpros.com/articles/how-to-replace-an-alternator
Mar 20, 2010 at 4:08 PM
MAGGIN
Electrical problem
2007 Dodge Caliber 4 cyl Automatic 54000 miles
This weekend my car completely wouldn't come on, so we replaced the battery. Once we replaced the battery, the car started right back up, with no issues! This morning, I get in and start the car, and the malfunction signal lights up. We're assuming the only other issue would be the alternator. I've read that installing a new alternator is a bit tricky on these vehicles. Can you provide step by step instructions on how to replace/repair the alternator? Also, do you have any other ideas as to things we should be checking? Thanks so much, in advance!
Oct 4, 2019 at 8:32 AM (Merged)
  • 110,248 POSTS
They are hard to replace because of space. Before replacing it, recharge the battery and drive it to a nationally recognized parts store and have them test the alternator on the car.
Let me know what you find.
