2008 Dodge Avenger Squeaky Wheel
31,600 MILES • 4 CYL • 4WD • AUTOMATIC
JLMAINOLFI
My 2008 Dodge Avenger has been making a loud squeaky noise for the past several weeks. It sounds like it is coming from the driver side front tire. The noise starts the moment the car is in motion (whether reverse or drive) and continues the entire time.
The Dodge dealership told me that the power streering fluid was low...they filled it up and it is still making the noise.
I had the tires rotated and it seems to be even louder.
Any suggestions??
Aug 18, 2009 at 3:33 PM
  • 31,937 POSTS
Hi there,
Did they check that the brake wear indicator tabs are not touching the rotors, this will make a similar noise, check this next.
mark (mhpautos)
Aug 18, 2009 at 4:17 PM
JLMAINOLFI
when I took it back for the second time they told me that the breaks were worn down and was touching the indicator...they didn't bother to check that the first time.
Thank you for the reply!!!
Aug 19, 2009 at 2:09 PM
  • 31,937 POSTS
I thought that may of been the case!, well its a good out come, safe driving and thank you for using 2carpros.
Mark (mhpautos)
Aug 19, 2009 at 2:20 PM
