2008 Dodge Avenger Replacing rear indicator bulb
35,000 MILES • 6 CYL • FWD • AUTOMATIC
STARBUKKANEER
  • 5 POSTS
Any ideas on how to replace a rear indicator bulb on a 2008 avenger? I found 2 plastic wing nuts in the trunk compartment that hold the lens in place but there seems to be something else holding it. Am I on the right track? Any ideas?
Thanks
Aug 22, 2009 at 9:45 AM
MIKE.SHRUM
  • EXPERT
  • 43 POSTS
Looks like the two wing nuts are all that holds it in the third tab is just a ball that pops in socket. try popping lens out
Aug 22, 2009 at 10:51 AM
STARBUKKANEER
  • 5 POSTS
[quote:f0d9ff63dd="mike.shrum"]Looks like the two wing nuts are all that holds it in the third tab is just a ball that pops in socket. try popping lens out[/quote:f0d9ff63dd]
Thanks for the reply. I tried popping the lens out with the 2 wing nuts removed, but the end with the tab didn't move. I didn't want to use too much force. It looks like a tab with a ball-bearing inside. Do I need to squeeze the tab first?
Thanks again
Aug 22, 2009 at 11:00 AM
MIKE.SHRUM
  • EXPERT
  • 43 POSTS
just looking at pic of light online. I have to go to town in a lil while i will look at a new one and see.
Aug 22, 2009 at 11:02 AM
STARBUKKANEER
  • 5 POSTS
Thanks Mike
Aug 22, 2009 at 11:07 AM
MIKE.SHRUM
  • EXPERT
  • 43 POSTS
have one more question for you. Can you not just twist the plug in and pull out assembly to change bulb? not sure never changed one on a new avenger
Aug 22, 2009 at 11:10 AM
STARBUKKANEER
  • 5 POSTS
Not sure, but I don't think it turns. I will try it in the morning.
Aug 22, 2009 at 11:28 AM
MIKE.SHRUM
  • EXPERT
  • 43 POSTS
that is how most lights are not sure if that one is that way or not let me know
Aug 22, 2009 at 11:34 AM
STARBUKKANEER
  • 5 POSTS
You were right the first time. The tab just pops out. I just had to use a bit more elbow grease.
Thanks for this.
Aug 23, 2009 at 1:10 AM
MIKE.SHRUM
  • EXPERT
  • 43 POSTS
Thanks for giving me chance to help
Aug 23, 2009 at 4:03 AM
