1999 Dodge Avenger wont move much or fast
192,000 MILES • 6 CYL • FWD • AUTOMATIC
BRINGMEALIFE88
the shifter will let u put it in all the gears, but only moves the car sometimes. once the car is in drive or reverse n is working it will let u move for a short distance at only about 10-15mph, and then acts like it's in nutral. the fluid isn't low. n the check engine light doesn't read any codes other then a coal system(not sure what it's called, but something to do with the emissions) n a crank shaft position sensor, but i had the sensor fixed.
Dec 7, 2009 at 9:21 AM
  • 75,988 POSTS
Why don't you try servicing the transmission and see what happens same thing, bring it in
Dec 7, 2009 at 9:30 AM
