1999 Dodge Avenger Oil Pressure
KLAVIERGRD
  • 1999 DODGE AVENGER
  • 6 CYL
  • FWD
  • 16,800 MILES
The oil pressure fluctuates consistent with the engine's RPM's. If, at a stop, the idle drops to 500rpm, the car dies. What's up?
Thursday, July 16th, 2009 AT 3:22 PM
  • 109,936 POSTS
It's normal for pressure to change when RPM's change. However, how low does it get? You could have a bad oil sending unit. That is the sensor that sends the signal to the gauge. Not an uncommon problem. As far as the engine dieing, has the check engine light come on? Have you checked for vacuum leaks?
Saturday, October 10th, 2009 AT 9:46 PM
