1999 Dodge Avenger VEHICLE STALLS
NATHAN PAYTON
  • 1999 DODGE AVENGER
  • 6 CYL
  • AWD
  • 135,000 MILES
EVERY TIME I COME TO A STOP THE VEHICLE STALLS CAN U TELL ME WHAT MUST I LOOK FOR TO SOLVE THIS PROBLEM
Wednesday, November 4th, 2009 AT 12:50 PM
CH112063
  • 1,320 POSTS
If your in a hurrey to find the problem a scanner will help. If you want to do it yourself and take a chance just try doing three things. Replace the air filter, and put new plugs in it, use NGK or Champions.
The throttle plate may also be dirty along with the throttle body, idle speed motor(called a idle air control motor) bore and the motor can be cleaned. If that does not work, well you have tried and you have eliminated the most likely cause, remember you have high mileage so there could be other problems. Ok
Monday, November 9th, 2009 AT 8:34 PM
