1999 Dodge Avenger oil leaks and major heat
1999 DODGE AVENGER
217,000 MILES • 6 CYL • 2WD • AUTOMATIC
SHRUMMER
hi my car has a major oil leak which looks to be coming from timimg belt cover and my car is surging really bad and there is major heat coming in through floor board on drivers side. do you have any ideas
Sep 26, 2008 at 3:40 AM
LEGITIMATE007
  • 5,121 POSTS
first of all , check all fluids including transmission. And the leak sounds like the crankshaft seal is shot and you may need a water pump. Is there any check engine lights on? If there are then take it to autozone for a free scan and come back with the codes
Sep 26, 2008 at 5:04 AM
SHRUMMER
no warning lights on
Sep 26, 2008 at 5:17 AM
SHRUMMER
oh and transmission is fine
