1999 Dodge Avenger had tuneup,fuel filter, fuel reg. tps, e
1999 DODGE AVENGER
GINAHPURPLE
Engine Mechanical problem
1999 Dodge Avenger 6 cyl Front Wheel Drive 655000 miles
came home and was going to back up and car died out. it turns on but when I step on the gas pedal it dies out. I tried to keep stepping on it but when I turn the ignition on it will shut off.
Mar 3, 2010 at 6:04 AM
LEGITIMATE007
  • 5,121 POSTS
clean the throttle plate and check the idle air control valve, change if necessary.
Mar 3, 2010 at 6:21 AM
