1999 Dodge Avenger Fuel Pump
178,450 MILES • 4 CYL • FWD • AUTOMATIC
TALLWALKER
How can you tell if a fule pump is "going out." I have power at low and high speeds and the car accelerates without problem. However, my fuel millage has dropped and occasionally I can faintly smell gas fumes.
Thank you[img:af268a1665]http://www.2carpros.com/forum/automotive_pictures/378711_SUNP0023_1.jpg[/img:af268a1665]
Jul 6, 2009 at 9:34 AM
  • 75,988 POSTS
By using a fuel pressure gauge and reading off the pressure. Running rich can be caused below
Possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode
Jul 6, 2009 at 9:44 AM
