It could be the Control Module that is mounted in the distributor causing your No Spark. It could also be the Crank Angle Sensor.
Did or is your Check or Service Engine light on? If so check with your local auto parts store and see if they rent code readers. If not try your local rental store.
You will need to pull codes this will help is find problem.
If you want a few ideas of what can cause your problem and some testing you may be able to do check out the site below.
https://www.2carpros.com/first_things/car_cranks_but_wont_start.htm
SPONSORED LINKS
Friday, February 6th, 2009 AT 2:29 PM
