1999 Dodge Avenger check engine light
87,500 MILES • 6 CYL • FWD • AUTOMATIC
RDJJIO
I have a 99 Dodge Avenger V6. The check engine light keeps coming on. Sometimes it's blinking, sometimes it's steady. We've checked the code w/ handheld computer & it reads P0302. Cylinder #2 misfire detected. I've replaced disributor cap, rotor, wires, plugs & gasket for upper manifold. We turned off the check engine light & everything was good for about 2 weeks. Now, it's on again reading the same code. The spark plug looks okay, no signs of misfire. Do you have any advice?
Dec 12, 2008 at 2:30 PM
ZACKMAN
  • 4,202 POSTS
Next step will be checking the fuel pressure on the fuel rail and also checking the #2 fuel injector.
Dec 12, 2008 at 3:58 PM
