1999 Dodge Avenger car cuts off while driving
150,000 MILES • 6 CYL • FWD • AUTOMATIC
CARICO11
99 dodge avenger 2.5 car runs great but sometimes it will stop running while driving and the rmp will drops and sometimes it wiil start back on its own when coasting to a stop and sometimes it will cut off.
I have change the fuel filter and fuel pump and the fuel pump relay.
Thanks
Jan 16, 2008 at 4:21 AM
2CARPRO JACK
  • 11,533 POSTS
I would try an ASD (auto-shutdown)relay. they have been known to do things like that and they power the PCM. Is the check engine light on? if so have it scanned and get back to me with the code/codes
Jan 21, 2008 at 7:20 AM
CARICO11
All relays are new the check engine light never comes on and it has been scanned three times and no codes have been found.There are several question on this forum from different people that has the same problem. So this must be a common problem with the Dodge Avenger. But no one knows what is causing the car to cut off while driving down the road and somethings it will start back by its shelf before you come to a stop and sometimes it will cut completely off. We have also switched out the pcm with a friend car and he has no problem with my but I still have the same problem with his pcm.
Thanks
Jan 21, 2008 at 8:43 AM
2CARPRO JACK
  • 11,533 POSTS
Have you tried a crank angle sensor?
Jan 21, 2008 at 9:16 AM
