1999 Dodge Avenger Brake light/fuel light
144,000 MILES • 6 CYL • FWD • AUTOMATIC
SIRTIMELESS
When i start the car both the Fuel light and brake light stay on. If i accelerate, the fuel light goes away and stays away until i let off the gas, but the brake light will not go away.
Dec 3, 2008 at 11:41 PM
  • 110,248 POSTS
Hi:
When the fuel light comes on, does the fuel gauge drop? Also, make sure the brake fluid is full and the e-brake lever / pedal is the entire way off and not sticking.
Finally, you can try resetting the BCM by disconnecting the battery for 5 or 6 minutes and reconnecting. That may help. Keep in mind, you will lose time and radio presets.
Let me know if this helps.
Dec 19, 2008 at 8:55 AM
