1999 Dodge Avenger 2ND CAR BATTERY LOSES POWER AFTER CHARG
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
MARFAYESTANLEY
hello, after being taken to three mechanics, problem remains and got worse.
the first that happened was that the alarm would start going off, usually in the evening, and powering down as the battery drained to nothing.
"auto zone" said possibly alternator needed replacing.
two mechanics say the alternator has been checked.
i have been able to drive after the car has been charged and driven around on the freeway for some amount of time. it seems that this problem had been reocurring for a while rarely and a every once in a while.
the last time in the most recent shop, it shows that it had been driven about 21 miles.
so it was brought home and battery had lasted through the next day and a half.
sometimes, a battery charge will last up to three days but not more usually.
then it was driven a shorter distance under ten miles and was dead the next day.
so at the last shop, the alarm and electric door locks have been disconnected but the alarm replaced but the last guy was unable to reconnect the electric door locks that i was very unhappy with. should he be responsible to repair the door locks that he did not put back in place? he claimed that the car was already "going down" before that and also failed to be there that day when i went to get the car to speak to me.
so, this problem is worse and worse. i am afraid to go anywhere as i may have to always be sure i am parked in a position thay jumper cables will reach. i am a single retired teacher older woman. i have been stranded at a gas station when i was afraid to pump gas cause i could not get it started again.
please advise. i really need your help and cannot afford alot of car repair right now or a new car. i appreciate your great help. thank you so much! God bless! as soon as i can i would like to donate to you. thank you.
Jun 22, 2009 at 6:38 AM
  • 110,248 POSTS
First, I too am a teacher. Still a little too young to retire. Only 11 more years. Second, I'm sorry to be getting back to you so long after your posting. There are so many that we try to answer that some get missed.
Regardless, I agree with you. If he disconnected the locks, he should be able to repair what he did. Also, I need you to try to check something. You will need a volt meter. It is easy to check, and then we will know if there is still a draw on the battery when the key is in the off position.
Here is a "How To" for you to follow. If you have questions, let me know and I will get back to you within a day. This time it will be sent directly to my email. If the problem has already been taken care of, let me know.
Oct 10, 2009 at 4:42 PM
