1999 Dodge Avenger
YOLONNI80
Engine Cooling problem
1999 Dodge Avenger 6 cyl Front Wheel Drive 115300 miles
I was driving my car and all of a sudden my car radio went off and my inside lights went dim and then temperature gauge shoot all the way up to hot. So i stopped the car put it in park and shut it down for a minute. I then started it back up and everything went to normal so i then turned around and headed home. I then looked down again the check oil light came on and it was running hot. So I then stopped again and shut down the car.Turned the heat off and my fog lights waited a minute. Started it up and again everything was normal got less then a block from my house when it happened all over again. Got in the drive way and parked the car. I tried to start the car again and it wouldnt start but the ignition turns over and oil light comes on. Its the only light the will come on. I just had the oil changed 3 days ago and there's nothing leaking and it wasnt smoking and ran fine before the oil change. I was wondering whether not it's the battery or if it could possible have the wrong oil filter? Or maybe fuel filter?
Jan 25, 2010 at 2:31 PM
  • 75,988 POSTS
I would say start by getting the battery and alternator load tested and go from there
Jan 25, 2010 at 4:14 PM
