1999 Dodge Avenger
64,000 MILES • 6 CYL • FWD • AUTOMATIC
SMORGAN
When I go to turn my car, either way, it makes this loud cranking/ rubbing noise? Anything on what it could be? My dad is a mechanic and he says its the strut bushing boot?
Apr 1, 2009 at 10:43 AM
CARADIODOC
  • 34,411 POSTS
Upper strut mounts. That's the bearings that hold the weight of the car but let you turn the steering wheel.
Apr 2, 2009 at 9:26 AM
SMORGAN
Okay, so I would be better if I just changed struts then right?
Apr 2, 2009 at 12:53 PM
CARADIODOC
  • 34,411 POSTS
Struts should not be bad yet at 64,000 miles; but then again, neither should your strut mounts. Have someone turn the steering wheel from full left to full right, (engine idling), while you hold your fingers around one of the front coil springs near the top. If the mount is binding, you'll feel a little tension build up, then it will pop and turn. The entire spring should turn very smoothly as the steering wheel is turned.
Very often binding mounts don't show up during a basic steering and suspension inspection. They might show up after the struts have been removed for replacement, then the mechanic has to find you and tell you, "as long as you have your wallet out, I found something else". They hate having to do that but it's better than putting in new struts with bad mounts.
caradiodoc
Apr 2, 2009 at 7:49 PM
SMORGAN
K, well my dad is a mechanic and he says that its just the strut boots, and when water gets up in there and drys out then the boot starts doing that.
Apr 3, 2009 at 1:32 AM
CARADIODOC
  • 34,411 POSTS
The boots are just flexible rubber covers that go over the top of the struts to keep water and dirt off of them. Dry is a normal condition. They turn with the strut shaft and do not cause noise or binding. Some boots are attached to the upper mount, some are attached to plastic or hard rubber "cushions" that slide up and down on the strut shaft.
The boots do not protect the bearings in the upper mounts. Those bearings are what binds and makes the noise you're describing.
caradiodoc
Apr 3, 2009 at 5:41 AM
SMORGAN
okay, then what should i replace?
Apr 3, 2009 at 8:14 AM
KARENCAREN
  • 72 POSTS
If you have your wallet open. Change your struts. But if not try to change the bearings that the source of the noise you are hearing.
Apr 21, 2009 at 12:42 PM
