Engine Mechanical problem
1998 Dodge Avenger 6 cyl Front Wheel Drive Automatic
I changed the timing belt, the pin in the cam gear sheared off and lost the timing, do you think that I have bent the valves? is this engine a zero clearance engine
Nov 10, 2008 at 11:48 AM
