1998 Dodge Avenger P0400 Code Random cylinder misfire
HOLLYWOODJT
Engine Performance problem
1998 Dodge Avenger 6 cyl Front Wheel Drive Automatic
New plugs, wires, cap, rotor button, TPS, carb cleaner, injector cleaner....... out of ideas
Mar 10, 2010 at 5:43 AM
LEGITIMATE007
  • 5,121 POSTS
hi, I think you mean p0300, random misfire. there are a few things that can cause this, a bad intake manifold gasket , egr valve, catalytic converter, even several bad injectors can cause this too
Mar 10, 2010 at 6:31 AM
SPEEDPROSHOP
  • 12 POSTS
scan and reading misfire misfire all plug 97 dodge avenger 2.4l 4cyl.. change coil ,plugs and wire,clean throttle body same problem all the time please help
https://images.2carpros.com/forum/automotive_pictures/511957_0921jin_20_1.jpg
https://images.2carpros.com/forum/automotive_pictures/511957_0921jin_20_2.jpg
Sep 23, 2010 at 8:52 PM
LEGITIMATE007
  • 5,121 POSTS
nice car, ok, you've covered all that. now you should check a couple of simple things, and all these cause a misfire, check/change air filter, pcv valve, and intake manifold gasket,/vacuum leaks.
Sep 24, 2010 at 3:03 AM
SPEEDPROSHOP
  • 12 POSTS
air filter new .let you no from your answer thanks
Sep 24, 2010 at 3:14 AM
SPEEDPROSHOP
  • 12 POSTS
[quote:120f341b57="speedproshop"]air filter new .let you no from your answer thanks[/quote:120f341b57]
maybe pcv when change plugs i add 2 with bit of oil on them
Sep 24, 2010 at 3:17 AM
SPEEDPROSHOP
  • 12 POSTS
i did lots of stuff spread around intake no leak
change sencor at and of throttle body no change
change one vacum pipe was crack no change
plug air filter coil wire all new added injector clener to gas and throttle body spray can in again no change
again random misfire ,clean every part
what is left to do
Sep 25, 2010 at 5:31 AM
SPEEDPROSHOP
  • 12 POSTS
[quote:c6198c1836="speedproshop"]i did lots of stuff spread around intake no leak
what is left to do[/quote:c6198c1836]
forgot change pcv ok
SPEEDPROSHOP
  • 12 POSTS
[quote:5d592285ae="speedproshop"][quote:5d592285ae="speedproshop"]i did lots of stuff spread around intake no leak
what is left to do[/quote:5d592285ae]
forgot change pcv ok[/quote:5d592285ae]
only thing left to do is change gas filter and check timing
Sep 25, 2010 at 5:38 AM
