1998 Dodge Avenger engine stalls
DOUG BURTCH
  • 1998 DODGE AVENGER
Engine Performance problem
1998 Dodge Avenger 6 cyl Front Wheel Drive Automatic
At slow speeds the engine rpm drops off when the steering wheel is turned hard and the engine stalls.
Sunday, February 8th, 2009 AT 11:50 AM
2CARPRO JACK
  • 11,533 POSTS
Slow speeds or when the engine is at idle? (Off throttle) Try cleaning the Idle Air Control Motor. Also clean out around the butterfly in the throttle bore with carb cleaner and a rag. This should help stabilize the idle.
Monday, February 9th, 2009 AT 7:47 AM
