1997 Dodge Avenger Vibration problem @ around 68 mph
66,000 MILES • 6 CYL • FWD • AUTOMATIC
THUNDR5
Hello there. I have a 1997 Dodge Avenger that I just recently put new tires on. They are 215/50/17 Uniroyal Tigerpaws, which replaced the Michelin Pilots that had been on the vehicle.
Since then, I've had a vibration problem. The wheels have been balanced twice, the alignment done twice as I had to replace the front stuts. My mechanic also went through the front end to check if anything was needed, as I know these cars had a recall on them for balljoints and control arms.
He says everything looks good. Still......it vibrates. It was never like that prior to the tire change.
I plan on checking the balance once more, as I'm suspecting a tire issue at this point.
What would your opinion be??
Thankyou.
Jim
Sep 26, 2009 at 9:31 AM
  • 110,248 POSTS
I agree with you. You could have a shifted or broken belt in one of the tires. I have a couple questions. Do you feel the vibration more in the steering wheel or the seat of the car? If you rotate the tires, is there a change?
Oct 10, 2009 at 1:22 PM
