1997 Dodge Avenger No air at all!!
13,800 MILES • 6 CYL • FWD • AUTOMATIC
TLC413
I have a 1997 dodge Avenger with 138,000 miles and when i turn the knob to turn on air nothing comes out, heat nor ac. Checked fuses and everything is good. What else could it be?
Sep 1, 2010 at 2:04 AM
  • 110,244 POSTS
Can you hear the blower motor checked?
Oct 5, 2010 at 1:37 AM
TLC413
I do not hear anything when i turn the knob. Could that mean it is the motor?
Oct 5, 2010 at 1:43 AM
  • 110,244 POSTS
It could be the motor or a few other things. I need you to check if the motor is getting power. If it is, the motor is bad. You can run a jumper wire to the motor to see if it runs. If there is no power, it could be a resister, relay, switch... Have you checked fuses?
Oct 5, 2010 at 2:31 AM
TLC413
Yes i checked the fuses first and they are fine but i will try to jump the motor tonight and see what happens. Well post results tomorrow...
Thank you
Oct 5, 2010 at 6:23 AM
  • 110,244 POSTS
Let me know what you find.
Oct 5, 2010 at 6:39 AM
