1997 Dodge Avenger chugging with engine light on
13,400 MILES • 6 CYL • FWD • AUTOMATIC
ANDREW2120
i have a 97 dodge avenger that started chugging and engine light was on. dealership diagnosis was number 4 cylinder had a misfire due to worn out boots on valave cover gasket. I changed out gasket and boots on plug well and put in new plugs and plug wires and now its chugging again. Computer diagnosis from autozone is picking up an injector malfunction on number four cylinder. How do i fix it?
Jun 11, 2010 at 10:16 AM
SATURNTECH9
  • 30,869 POSTS
Could you please get me that code number's your car has so i can help you with this.
Jun 11, 2010 at 10:42 AM
ANDREW2120
I am not sure of what code number you r talking about. I didnt take the car to autozone but my girlfriend did. She just brought me the printout from the computer reading
Jun 11, 2010 at 12:03 PM
SATURNTECH9
  • 30,869 POSTS
Well on the print out there should be some code number's they will start with the P and have four digit's after that.So tell me what they all are.
Jun 11, 2010 at 2:46 PM
ANDREW2120
Ok well the code that the computer was picking up was po204.
Jun 12, 2010 at 3:53 AM
SATURNTECH9
  • 30,869 POSTS
I emailed you the information for you code p0204 to your personal email.Let me know what you find.
Jun 12, 2010 at 6:30 AM
ANDREW2120
ok thanks i'll check my email for the info.And one more question.. Do you happen to know the torque specifications for the air intake bolts?
Jun 12, 2010 at 7:56 AM
SATURNTECH9
  • 30,869 POSTS
Do you mean for your air filter box or your intake manifold?
Jun 12, 2010 at 9:43 AM
