1997 Dodge Avenger
1997 DODGE AVENGER
97,000 MILES • 6 CYL • 2WD • AUTOMATIC
SLICKWILLY1949
not receiving fire from distributor, have replaced crank sensor and distributor with new cam sensor. still no fire,fuses are all good.does this vehicle have a auto shut down relay that could go bad and cause this problem? if so where is it located? Thanks Bill
Dec 23, 2007 at 9:25 AM
BLACKOP555
  • 10,386 POSTS
you may need a new coil, follow the wire that goes from the distributor center.
Dec 23, 2007 at 1:59 PM
