1996 Dodge Avenger transmission
1996 DODGE AVENGER
126,000 MILES • 6 CYL • FWD • AUTOMATIC
TWINKIE08
Hi everyone i like to thank you for this site, because sometimes its good for people like me to ask before even going to a shop. So here is my question:
MY CAR IS A ´96 AVENGER WITH A 2.5 LITER ENGINE, AUTOMATIC TRANSMISSION, IT WAS WORKING FINE, WE STOP USING IT FOR ABOUT 18 MONTHS BECAUSE WW MOVE OUT OF TOWN WHEN WE CAME BACK THE TRANSMISSION WASN´T WORKIG IT ONLY STAY IN 2ND. GEAR WHAT I MEAN IS THAT IT ONLY STAY IN ONE GAR AND NEVER CHANGE.
I WAS THINKING AT THE TRANSMISSION CONTROL SOLENOID?
SO IF YOU HAVE ANY CLUES LET ME KNOW I WILL APRECCIATE. THANKS
Nov 30, 2009 at 12:34 PM
  • 31,937 POSTS
Hi there,
This may just be a stuck shift valve or solinoid, go get it serviced at a transmission work shop, they will also be able to give you a report on any problem that they may find.
mark (mhpautos)
Nov 30, 2009 at 12:38 PM
TDCRAIG
[quote:8eabd6cb42="twinkie08"]Transmission problem
1996 Dodge Avenger 6 cyl Front Wheel Drive Automatic 126000 miles
SO IF YOU HAVE ANY CLUES LET ME KNOW I WILL APRECCIATE. THANKS[/quote:8eabd6cb42] having same problem did you fix problem?
Jan 29, 2010 at 2:42 AM
TDCRAIG
having same problem did you find solution?
Jan 29, 2010 at 2:45 AM
TDCRAIG
[quote:e597b9cb92="mhpautos"]Hi there,
i put in different trans still same problem!!!
mark (mhpautos)[/quote:e597b9cb92]
Jan 29, 2010 at 2:48 AM
JUANLANAS13
  • 10 POSTS
The tranny is in limp mode and stays in second gear so that the tranny dose not hurt itself. I would replace the tranny filter and fluid first. then take it to a shop so they can hook up a reader. Make sure you put ATF+4 fluid
Feb 1, 2010 at 12:29 PM
