1996 Dodge Avenger surges and not getting enough gas
1996 DODGE AVENGER
120,000 MILES • 6 CYL • FWD • AUTOMATIC
COWBOYS1234
My car seen like its not getting enough gas. When i stop at the light and try to take off it surges and go slow than it go. I replace wires, plugs, sensors , fuel pump, and injectors and now i going to replace the fuel pressure regulator. Once it go it go, but then when i stop it starts all over again. Some say it the distribtor.
Feb 24, 2009 at 7:05 AM
ZACKMAN
  • 4,202 POSTS
You have a vacuum leak. Look at every single vacuum hose under the hood. One of them is either unplugged, broken, or has a hole. Also look at your EGR valve, EGR solenoid and the pipe where it is attached to the block and to the manifold.
Feb 24, 2009 at 8:43 AM
COWBOYS1234
i replace the egr valve no luck, the car feel like it not getting gas, it cutting out when driving
Feb 26, 2009 at 5:27 AM
ZACKMAN
  • 4,202 POSTS
Do you happen to have the check engine light on?
Feb 26, 2009 at 12:08 PM
ZACKMAN
  • 4,202 POSTS
Also, coupe or convertible? ***Never mind*** Of course it is a coupe. What was I thinking!!
Feb 26, 2009 at 12:39 PM
ZACKMAN
  • 4,202 POSTS
Here is the diagnostic for hesitation
https://images.2carpros.com/forum/automotive_pictures/55316_hesitation_1.jpg
Feb 26, 2009 at 12:44 PM
