1996 Dodge Avenger I just cant figure it out
DODGE*DEMON
Computer problem
1996 Dodge Avenger 6 cyl Two Wheel Drive Automatic
I have a 96 dodge avenger. 2.5L v6. the motor was pulled to repair an oil leak at the rear seal. While the motor was out we did a complete make over on it replacing all seals & gaskets. We cleaned it up and even painted it so its like brand new. Then we checked all wires from the firewall to the wiring harness and made sure they were good before dropping the motor back in. Once it was in we tried it and there was no spark to the plugs so we changed out the crank sensor. Still no spark. Next we changed the distributor and cap, again no spark. We then went thru and checked all fuses, they are fine. The starter is brand new, battery is new, plugs and wires are new. When we turn the key on we can hear the relays click and the fuel pump go on, but it wont spark to the plugs. Did I maybe miss something here? Please help!!
Mar 26, 2010 at 4:44 PM
LEGITIMATE007
  • 5,121 POSTS
did you check the ignition coil?
Apr 18, 2010 at 2:57 PM
