1996 Dodge Avenger acceleration hesitation
1996 DODGE AVENGER
KELLYBISIO
Engine Performance problem
1996 Dodge Avenger 4 cyl Two Wheel Drive Manual
We just purchased this vehicle and it has a slight hesitation on acceleration, not all the time just periodically, and a very bad shake any suggestions????
Jul 16, 2008 at 2:28 AM
Possible Causes of Engine Hesitation
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Jul 16, 2008 at 2:32 AM
