1996 Dodge Avenger
ETOWNSEND
Steering problem
1996 Dodge Avenger 4 cyl Two Wheel Drive Automatic
my car is very hard to to turn both ways. do anyone know what the problem could be.
Nov 12, 2008 at 4:20 AM
ZACKMAN
  • 4,202 POSTS
Check your power steering system. Is the belt tight? Do you have enough P/S fluid? Does it make any noise with the engine running?
Nov 12, 2008 at 1:03 PM
ETOWNSEND
the belt is loose do you think thats is the problem. the power steering fluid isn't low.
Nov 13, 2008 at 10:40 AM
ZACKMAN
  • 4,202 POSTS
If the belt is loose, and no noise from the pump; chances are that is your solution. Make that belt tight.
Nov 13, 2008 at 2:50 PM
