1995 Dodge Avenger TIMING BELT COVER
PATRICK AUMANN
Engine Mechanical problem
1995 Dodge Avenger 4 cyl Two Wheel Drive Automatic
I'VE REMOVED THE FRONT OF THE ENGINE AND FRONT OF CAR MOTOR MOUNTS.ROMOVED CRANESHAFT PULLEY. UNBOLTED TIMING BELT COVER. I'VE LOWER THE ENGINE, RAISED THE ENGINE BUT CAN NOT FIND ENOUGH ROOM BETWEEN FENDER WELL AND TIMING BELT COVER TO REMOVED THE TIMING BELT COVER BOLTS. HOW DO I REMOVE THE BOLTS?
May 1, 2008 at 3:02 PM
2CARPRO JACK
  • 11,533 POSTS
Do you mean the motor mount bolts on the front cover? nice design isnt it? If I remember correctly, I lift the engine until they clear on some and lower on another.Still might need to pry the engine back just a little to make the whole thing clear
May 3, 2008 at 1:01 AM
