1995 Dodge Avenger output speed sensor
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
ILUVWHTCHIX
I changed the output speed sensor after the code came up but the slippage still happens though just not as bad. What else could be cause the hard shift?
Sep 22, 2008 at 10:41 AM
BMRFIXIT
  • 19,053 POSTS
WE ALWAYS REPLACED the two sensors input and output
with no problems to follow
I would also check TCM for codes
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Sep 22, 2008 at 11:13 AM
