1995 Dodge Avenger no interior heating
JWFENTON
Heater problem
1995 Dodge Avenger 4 cyl Front Wheel Drive Automatic
my sons car is not getting any heat inside. i first checked coolant level, then replaced thermostat, blowers inside is working. barely any heat at all. not sure if it would be a vaccuum hose, maybe the heater core, or a relay. any suggestions?
Jan 2, 2010 at 10:14 AM
  • 75,988 POSTS
Check the heater core if its clogged-up, and also if it has a heater control valve check that too. if both okay-the problem exist inside could be an air mix/blend/mode/ door problems to include vacuum/actuators and the HVAC control module
Jan 2, 2010 at 3:46 PM
