1995 Dodge Avenger engine power loss
DFRAI
Engine Mechanical problem
1995 Dodge Avenger 6 cyl Front Wheel Drive Automatic
When you try to accellerate the engine bogs out. I changed the fuel filter and drove it to get it inspected and the car ran fine. Until, they put it on the dyno machine. The car bogged out and misfired especially when the transmission shifted gears. When you try to accelerate, the engine just loses power for about 4-5 seconds and kicks in. The transmission seems to be fine and shifts normally. Can you please help? Tnahks....
Aug 11, 2009 at 10:53 AM
  • 110,248 POSTS
Has the check engine light come on? Have you had the fuel pressure tested? Finally, have you checked for vacuum leaks?
Oct 10, 2009 at 2:25 PM
