Computer problem
1995 Dodge Avenger 4 cyl Front Wheel Drive 104000 miles
when the key is turned on most of the indicator lamps in the dash do not light including the check engine. I was going to try to pull the codes from the PCM to try and figure out why it was not starting I think it's not starting because the PCM is dead. Is there any way to check
Dec 22, 2007 at 9:13 AM
