1995 Dodge Avenger 1995 avenger noise
1995 DODGE AVENGER
175,000 MILES • 6 CYL • FWD • AUTOMATIC
XAVENGER_GIRLX
hi i have a 1995 avenger with 175xxx i have recently been hereing this horid noise from the front when i turn just to keep you up to date my suspension is going so i dont no if that has anything to do with but it sounds like nails on a chalk board well somewhat i have no clue what it could be i have already taken it it for a wheel alignment a new hub and bearin on the passengers side and that was a few months ago but this noise started about 2-3 weeks ago and i have no clue what it could be and no one is helping me out they say my car is fine but it's obviously not
Mar 5, 2009 at 9:58 AM
MERLIN2021
  • 17,250 POSTS
Could be the brakes need replacing, the wear sensor could be just starting to touch the rotor.
Mar 5, 2009 at 10:18 AM
JAMES W.
  • 2,394 POSTS
OK, here we go. A couple of questions. When your car is running, standing still and in park, if you turn the steering wheel all the way to the left- then all the way to the right, then back to center, do you hear the noise? Or, is it only when the car is moving? Is the noise more pronounced when you turn to the left than to the right? Please advise.
Mar 5, 2009 at 10:23 AM
XAVENGER_GIRLX
it does make that sound still when im in park and i turn the wheels. it sounds like its comming from both ways but somethings it sounds more fromt he right then the left, cause i guess the owner before hit a curb thats why i had to replace my bearings
Mar 5, 2009 at 10:32 AM
XAVENGER_GIRLX
[quote:f0de734f0d="James R. Weizel"]OK, here we go. A couple of questions. When your car is running, standing still and in park, if you turn the steering wheel all the way to the left- then all the way to the right, then back to center, do you hear the noise? Or, is it only when the car is moving? Is the noise more pronounced when you turn to the left than to the right? Please advise.[/quote:f0de734f0d]it does make that sound still when im in park and i turn the wheels. it sounds like its comming from both ways but somethings it sounds more fromt he right then the left, cause i guess the owner before hit a curb thats why i had to replace my bearings
Mar 5, 2009 at 11:02 AM
JAMES W.
  • 2,394 POSTS
What it sounds like is the pivot bearings in the top of your strut towers are shot. When these are bad they will make a grinding noise when turning or a thumping noise when going over rough roads. You may want to get this checked out.
Mar 5, 2009 at 12:04 PM
JAMES W.
  • 2,394 POSTS
Complete.
Mar 21, 2009 at 1:36 PM
