1986 Dodge Aries No Heat
REBLREED
1986 DODGE ARIES SE 164000 MILES
WE HAVE NO HEAT FROM HEATER. NEW THERMOSTAT , NEW HEATER VALVE , PLENTY OF FLUID . WHAT DO WE CHECK NEXT ???
Jan 12, 2007 at 3:29 PM
2CARPRO JACK
  • 11,533 POSTS
Is the cable from heater valve to controller working?. Might be a blend door problem under the dash
Jan 13, 2007 at 12:01 AM
REBLREED
CHECKED BOTH THE CABLE AND BLEND DOOR . SEEM TO BE WORKING. COULD IT BE HEATER CORE??
Jan 15, 2007 at 11:01 AM
2CARPRO JACK
  • 11,533 POSTS
Check the heater core and hoses for restrictions preventing water from getting in
Jan 16, 2007 at 4:34 AM
Suggested Repair
Check the heater core and heater hoses for restrictions that prevent coolant from flowing through the core.
Conversation Summary
A 1986 Dodge Aries with 164,000 miles has no heat despite a new thermostat, a new heater valve, and adequate coolant. The heater-valve cable and blend door were checked and appeared to work. The expert advised checking the heater core and hoses for restrictions blocking coolant flow.
