1989 Dodge Aries WILL IT GO FASTER THAN 40mph??
MAGIKAL
Engine Performance problem
1989 Dodge Aries 4 cyl Two Wheel Drive Automatic ALOT miles
car revs up fine at idle. accelerates mildly to 40 mph then it just bogs out when you hit the gas above this speed. No check engine lights visible. Assume plugs, wires, etc are all good. No smell of it running rich at all...
Ideas?
Gonna check fuel pressure and filter, and air flow. This isn't my car, I am just trying to assist an elderly man w/ the computer stuff.
Also, what is procedure for self-diagnostics and whose got a list of codes?
Thanx all!!!
Jan 20, 2009 at 7:10 PM
BILLYMAC
  • 2,204 POSTS
hi codes we have listed on this site or any auto parts store. the sequence turn key on and off three times. wil flash code 12 three times. flash pause 2 quick flashes. then codes will start then code 55 end of message. good luck billymac
Feb 21, 2009 at 1:20 PM
