1989 Dodge Aries starting problems
V3030DDR
I have a 89' Dodge Aries and it is having starting problems. I can get it started if i keep at it for a while but if it sits over night it will start and then immediately shut off. Why is it doing this, i thought it was something to do with the carbourater
Feb 19, 2007 at 3:33 AM
  • 75,988 POSTS
[quote:70d77690a0="v3030ddr"]I have a 89' Dodge Aries and it is having starting problems. I can get it started if i keep at it for a while but if it sits over night it will start and then immediately shut off. Why is it doing this, i thought it was something to do with the carbourater[/quote:70d77690a0]
Verify whether its a Carb or an EFI system
Feb 19, 2007 at 8:34 AM
V3030DDR
[quote:df97eda710="rasmataz"][quote:df97eda710="v3030ddr"]I have a 89' Dodge Aries and it is having starting problems. I can get it started if i keep at it for a while but if it sits over night it will start and then immediately shut off. Why is it doing this, i thought it was something to do with the carbourater[/quote:df97eda710]
Verify whether its a Carb or an EFI system[/quote:df97eda710]
well i believe its a carb, unless they look the same
Feb 20, 2007 at 10:28 AM
  • 75,988 POSTS
[quote:c43ca114bf="v3030ddr"][quote:c43ca114bf="rasmataz"][quote:c43ca114bf="v3030ddr"]I have a 89' Dodge Aries and it is having starting problems. I can get it started if i keep at it for a while but if it sits over night it will start and then immediately shut off. Why is it doing this, i thought it was something to do with the carbourater[/quote:c43ca114bf]
Verify whether its a Carb or an EFI system[/quote:c43ca114bf]
well i believe its a carb, unless they look the same[/quote:c43ca114bf]
You need to check the fuel pressure before we continue
Feb 20, 2007 at 5:07 PM
