1989 Dodge Aries Speedometer doesn't work
MIKEMUSIKA
Electrical problem
1989 Dodge Aries 4 cyl Front Wheel Drive Automatic
My machanice said that it had to do something with the transmission and the speedometer being conected, and that he couldn't find where he was supposed to connect them. Lil help?
I have a Dodge aries 89, 2.5 lt.
Front wheel drive, 4 cyl, transmission is a automatic.
May 6, 2009 at 6:44 AM
CARADIODOC
  • 34,416 POSTS
Don't have any idea what you're asking. The speed sensor is a common cause of an inoperative speedometer and the odometer not advancing.
1988 models still used a speedometer cable connected to the speed sensor. 1989 and newer models use just the sensor, no cable. If your car is a mid-year model with no cable, change the sensor. If it has a cable, check the end of the cable to see if the square end is rounded off.
caradiodoc
May 9, 2009 at 5:03 PM
MIKEMUSIKA
Where would the cable and sensor be located?
Jul 8, 2009 at 9:48 AM
