1988 Dodge Aries getting multiple codes
1988 DODGE ARIES
122,000 MILES • 4 CYL • FWD • AUTOMATIC
SCOTTY3131
every time i try starting my car it starts and then dies unless i rev the gas.the codes i keep getting are 15,21,37,52,and 55. please help
May 31, 2008 at 5:10 AM
CH112063
  • 1,320 POSTS
15= No vehicle speed sensor
21= O2 sensor stays at center or shorted to voltage
37= Torque Converter Clutch Solenoid circuit
52= O2 sensor signal stays above center
55= completion of codes, diagnostics over
Disconnect neg. battery cable. Wait a couple minutes. Hook it up and try starting it about 5 or 6 times then recheck codes to see what you have. The Aries map sensor was a notorius start and stall tow in, but by 89 it was better. I hope its ok by now. Your problem may be something else than the codes you listed. Good luck. This is a 2.2 or 2.5 correct?
Aug 27, 2009 at 11:59 AM
