1988 Dodge Aries Air Bl;end Switches
95,000 MILES • 4 CYL • 2WD • AUTOMATIC
STANMI
When I turn the heater or air conditioning on, I can only get air flow through the window defrost. I cannot get air flow to the panel, floor or any other combination.
I replaced the vacuum heater control valve but I guess it was a waste of time.
What controls the air blend selector?
Oct 4, 2008 at 5:18 AM
  • 110,248 POSTS
Hi:
There is a vacuum diaphragm under the dash. It should be located on the passanger side inder the dash. Check it.
Oct 22, 2008 at 12:32 AM
