1987 Dodge Aries starter won't turn off
120,000 MILES • 4 CYL • FWD • AUTOMATIC
STEVEKAR3
Hello, when I start up my car the starter will not disengage, I then turn off the ignition and pull the key out and the starter is still engaged and turning the engine over, only when I disconnect the battery terminal the starter stops, I installed a new ignition switch and the same thing happens.
thanks steve
Feb 12, 2008 at 11:27 AM
MASTERTECHTIM
  • 4,750 POSTS
try unhooking the smaller wire at the starter and see if that works. if it still cranks over then your starter motor is no good. if it doesnt you have a shorted wire.
Feb 12, 2008 at 11:39 AM
JDL
  • 16,098 POSTS
You might try unplugging the starter relay. See if that helps.
Mar 21, 2008 at 11:10 PM
